Rigid Tapping G84 update
MaccaRnD
MaccaRnD
Just wondering how the Tapping cycles are going weather they will be updated or implemented soon, rigid Tapping G84 is the main one I m interested in, it was mentioned three years ago that it was being worked on, is there an update, there seems to be a lot of talk on other forums about people turning away from Masso for not providing software and G codes like many of the other systems out there. Could we please get an update.
@macarms,
Could you supply your serial number, so we can create test software for you to test.
This will be made available via myWorkshop. You will need to be registered as a beta tester to download it.
MaccaRnD
MaccaRnD
Thanks for getting back to me, that s good news you s are looking to roll out Rigid tapping, The mill I want rigid tapping on I m still waiting to hear back some details on a Spindle driver or closed loop VFD for it, once I have them I will see if Masso can run it, before I purchase another Masso controller for it,
I want to be able to run 5 axis simultaneous and have a spindle that I can orient/index
Does Masso not currently support rigid tapping? We were planning on retrofitting 3 VMC's and without rigid tapping as an option we will have to look for a different control option.
Perhaps I should have asked how can a controller in this day and age not support rigid tapping?
I’ve already see the links you provided. I’m trying to figure out how to use this controller with this limitation and no thread milling isn’t a solution. It’s not a fast enough process. We need to be able to rigid tap to consider this control. Currently I am thankful we cancelled our order so we can find a solution.
GHT_LLC
Member
So I used AI to make a ridged tapping cycle without using G84. Haven’t tried it yet though
; Set the tool and work offsets
G54 G90 G17 G40 G49 G80
; Rapid positioning to the starting point
G00 X0 Y0 Z5
; Spindle setup
MSG Set spindle speed and direction
S1000 ; Set spindle speed (adjust as needed)
G97 S1000 M3 ; Start the spindle clockwise at 1000 RPM
; Linear move to tapping depth
G01 Z-10 F50 ; Move to tapping depth at a feed rate of 50mm/min
; Dwell for a short duration to simulate tapping
G04 P1 ; Dwell for 1 second (adjust as needed)
; Stop the spindle
M5
; Reverse spindle direction
G97 S-1000 ; Set spindle speed for reverse
M3 ; Start the spindle counterclockwise
; Rapid retract to a safe position
G00 Z5
; Stop the spindle
M5
; End program
M30
DavidR8
Active member
From Masso Support:
Hi David
Thank you for your email,
At present MASSO software is undergoing a full review.
Rigid tapping remains one of the features that is remains a priority however the software review and update needs to be completed first.
Once this is completed new features like Rigid tapping are planed to be added.
Regards Peter
DavidR8
Active member
Subsequent to the email from Peter, I received an email from Jatinder, Masso founder & CEO.
He didn't mince words; the delay in bringing this forward is all on them. He acknowledged that. So good on him for that.
They are working hard on a "major software version rebuild" that had to take priority.
Once that rebuild is done rigid tapping and other delayed items can go into the next release.
Props to @jatinder for being transparent about the delays and priorities.
