Rotary for router mill
rroie
rroie
I have my router cnc up and working. Thanks to all the help I got here. Now I want to hook up my rotary, fourth or fifth axis? I do not know if Masso will do that. I hope so. I have done it in Mach3 but do not know where or how to start in Masso? I have the Y and B axis wire parallel.
Thank You
Roie
Nice machine rroie
Traditionally the A axis is used for rotary.
Just connect your stepper motor driver to the A axis and put a check in the Angular Axis box on the axis setup screen. This will change the settings to degrees and you can fill in the appropriate settings from there.
Regards
Roie,
Further to what Peter said you need to calculate your settings as follows,
The degrees per revolution value, how many revolutions does the stepper make for a complete revolution of the chuck?
Divide that value into 360 and enter the resultant figure into MASSO A axis setup.
rroie
rroie
Trying to figure this thing out. I guess I am going to add a stepper driver for the A axis. The stepper motor has to turn 36 rev for one of the chuck. When I put those numbers in the A axis setup screen it says at the top .5Khz pulses per rev. Does that mean 500 pulses per rev on the DM542T stepper driver?
Do not understand pulses per rev or where to get it. The rest of the DM542T stepper drivers are set at 1600. Of course those are direct drive.
I assume I must disable the Y axis somewhere when I use the Rotary?
Any and all help is surely appreciated
Roie
rroie
rroie
Just saved and reopened the A axis set up box and now it looks like this:
Quote from rroie on August 11, 2019, 6:58 pm
The Pulses per Revolution is the number that you have set the driver too. The number that appears at the top of the setup screen is the result of the figures you entered.
The best thing to do is set the driver to the same settings as your other drivers and adjust the figure in A axis setup.
Pulses per Revolution is the number of pulses the driver will send to the stepper for it to complete one revolution. The fact that the steppers are direct drive or geared doesn't come in to it.
You shouldn't need to disable the Y axis as long as your CAM software produces the correct gCode to rotate the A axis.
You may need to adjust the figures in the A axis setup to calibrate the rotation.
Hope this helps you to understand.
rroie
rroie
What is the correct g code? Aspire does not have Masso rotation. Has Mach2/3-WrapY ATC(inch)(*.txt). Has metric also. Mach2/3-Wrap work in Masso?
If not what cad, g code generator do I need?
Thank You
Roie
peter35
Peter35
I have used fusion 360 on my mill, l am running ac servo motors on my mill and my 4th axis, rotary table, is a stepper motor.
  • 200-x-111.5-roller-Drawing-v8.pdf
@rroie @masso-support
Don't know much about Aspire, you'll have to get Peter of MASSO Support to write/modify Aspire's MASSO post processor.
I myself use Fusion 360 to produce my CAD & CAM.
Mach 2/3 Wrap would probably work. You would need to check the gCode that the G & M commands contained therein are supported by MASSO.
If you haven't printed the MASSO CHEAT SHEET I suggest that you do.
Regards
Hi rroie
It's on my list to look at the rotary axis post processor and see if I can make one for Masso in Vectric software.
I will see what I can do.
Hi rroie
Here are the post processors I created for VCarve and Aspire. There are 4 new post processors and they will work with all versions of Aspire 2.1 and greater / VCarve Pro 5.1 and greater.
The rotary axis is output as the A axis to suit Masso.
I have not tested these so please be careful. Do a quick visual inspection of the GCode first, let me know if you find any issue with them and I will get it fixed ASAP.
  • Masso-Post-Processors-for-Rotary-Axis-Vectric-Aspire-VCave-Pro-all-versions.zip
Thank you Peter.
I knew if your attention was drawn to it, Roie's problem would solved.
rroie
rroie
Thank you every one for the responses. I have printed the cheat sheet. Fusion 360 is pricey and cloud based. I am not much for subscriptions. I have Solidworks but just use it to convert file types. Should buckle down and learn it I guess. I know nothing about g code. Use Aspire for design software and to generate g code for me. Have two E-Stop buttons for when I get in trouble. I will get the A axis stepper driver installed to day and will give the post processor a run.
Thank You so very much guys
Roie
PS: I have lost three computers this last year. Lost all pictures. Here is a sample of what I was doing on the old Gatton Router CNC.
Quote from rroie on August 12, 2019, 12:13 pm
Fusion 360 is free for hobbyist and business with income < $100k. Just look for hobbyist when signing up.
You have to renew your subscription each year.
There are lots of youtube channels on the use of Fusion, some of the best are
That's how I am learning.
I knew nothing about gCode before I started this journey with the Bicton Men's Shed CNC Router. When you see a gCode command that you don't understand just google it, there are plenty of sites that explain each command.
rroie
rroie
Well, I certainly qualify for a free version. So maybe I will give it a try. YouTube is how I learned Aspire. Appreciate the links. Can not thank you enough for all the help.
Thank You
Roie
