SheetCAM Post Processors for MASSO
Yes it has the built in G32.8 command that will automatically gets added to the gcode to zero the work piece every time you start a new cut.
peter35
Peter35
l have been using sheetcam on my milling machine with mach 3 without any problems.
I am now using the masso post processor and this appears to be for plasma only, can this be modified to suit the mill.
At the moment when job starts, the Z axis collides with top of job and then lifts to start point. I would expect this with a touch plasma torch but no good for the mill.
I have been playing with hsmxpress which does work but very time consuming for simple jobs.
Plasma POST is different to Mill as its got the probing cycle built in. Which post you have been using with MASH 3?
peter35
Peter35
I am running the latest version of sheetcam, 6.1.53.
I believe l have been using the following
Mach3 post processor
Non modal G-codes
Modal coordinates
Comments enclosed with ( and )
Incremental IJ
uses G43 tool length offsets
As l have changed to the Masso l do not have a PC with Mach 3 running at the moment to confirm.
P.S. I now have the Extron up and running, So unfortunately the King Rich has not been used the last few days.
We will have a POST for mill version made, can you share one of your sheetcam JOB files with us so that we can send you some gcode files for you to check.
Ross
Ross
Great if this is added to your list of post processors.
From Ross.
Quote from MASSO - Support on June 29, 2018, 1:36 pm
rcrclr
rcrclr
I click on the [ click here ] spot on the sheetcam post processor and it goes to a page of script no downloading of a file
just checked the links and they are are working fine. maybe your browser is opening them in the browser, can you make sure to download the files to the computer and then use with sheetcam.
Quote from MASSO Support on June 29, 2018, 1:36 pm
Quote from Peter35 on June 30, 2018, 12:00 am
Have attached sheetcam file with Mach 3 post
Quote from Ross on February 2, 2019, 3:57 am
Hi Masso, any news on the Mill update,
@masso-support
Has there been any progress on providing a MILL version POST processor for SheetCam?
If there has, where is it available for download?
See also topic Post processors for SheetCam.
