Sherline Loosing steps on the X & Z axis
Reported by user @grindaur
I am running a Sherline/Masso setup using their standard Nema 23 motor (3.2V 2A, 1.8 /step 530 RMP max). The program is running a 3/16" end mill with spindle speed of 2000 RPM, cutting feed rate of 40"/minute, ramp feed rate of 40 "/minute). The issue is both the Z axis and today the x axis are loosing the zero point mid way in the program this has resulted in twice plunging toward the center of the earth and milling my tooling plate. Today the x axis reset to approximately 1" positive of the point it was supposed to be at . There was no readout change, the operation was a contour milling operation there was no tool retract/rapid movement involved. The program was run though simulation on both Fusion 360 and using GWizard, the issue is not with the Gcode. What do I do to address this. I cannot proceed when the past three attempts at milling a part have resulted in trashing the unit being machined?
Hi @grindaur
Could you tell us a bit about your machine please.
The machine sounds like a Mill but could you confirm.
  • What software version are you running?
  • Could you provide screen prints of the X & Z axis settings?
  • Has Sherline be able to offer any insight into the problem?
There are many reasons machines loose position but the common ones are.
  1. Mechanical problems of which the most common are axis binding or slipping couplers
  2. Settings problem. eg acceleration or maximum feed rate set wrong in the controller.
The one thing on your side it that it sounds like a serious problem which believe it or not is a good thing.
It will be easy to reproduce and figure out what is happening.
I will take this type of problem over an intermittent one any day.
@cncnutz - Sherline mills and lathes use a threaded rod by default for the lead screw (unless someone is willing to pay the extra for ball screw). Normally the threaded rods are hidden "below decks" and out of the way as far as swarf and dust is concerned.
@grindaur - What material are you profiling? Something that would make nice long chips or fine dust like brass or wood?
The Z axis of the Sherline mill (from personal experience) will be the one likely to bind, the Z axis threaded rod is exposed at the back to air and will collect dust if it is properly oiled. I would start with wiping down the Z axis screw and reapply some appropriate lubricant. Double check that the column lock is not engaged and the backlash adjustments are reasonable (with the threaded rod you can't have the backlash adjustment too tight or it applies extra load on the axis).
I have upgraded my Sherline mill from threaded rod to ball screw due to the speed limitations of the axis before loosing steps (the Z axis was the worst due to the load it was carrying). Going to ball screws resulted in much lighter loads on the axis even though the pitch jumped from 1mm/rev to 2mm/rev.
If you are doing a fair amount of Z axis movement you may want to consider counterbalancing the Z axis
I would be loading a dial indicator into the spindle and running the Z axis up-and-down at different feed rates to see at what speed do you start loosing steps. Do you loose a few steps or does the axis stall completely? A complete stall is likely to be stepper motor resonance or binding of the axis.
Peter - Do you have any good links on tuning stepper motor maximum speed / acceleration parameters?
grindaur
Grindaur
This is my 6th attempt this morning to respond. I will start with the requested info from CNCnutz:
SN is 5A-3029
Core V1.26
Software v3.48PID
The application is indeed a Mill, (Sherline 5000 series). I am attaching all one axis setup at a time since it appears to crash the server if I include 3, please let me know if there are other screens to capture.
grindaur
Grindaur
Much apologies to all I am a luddite, once I realized that my problem was a corrupted file for the Z axis, and then looked at the screen when I tried to reload the Z axis data I realized several things:
  1. I reaffirmed that I am a Luddite
  2. The data you were looking for was the initial screen that i had been closing
  3. The issue with my program is probably on the gcode end. Fusion 360 assumes that you are using a machine on steroids, I had loaded a much reduced feed rate for my tool setup but low and behold I was over what the Masso was setup for as maximum feed rate as Sherline provided in the initial setup. X and Y are 32 ipm with acceleration of 6 ipsec2, Z is 15.0 ipm, acceleration of 6 ipsec2. My settings were 40 ipm for x and y and 2 ipm plunge rate for z. Not sure why the z is a problem but starting to understand what might of happened yesterday. I am going to try rerunning the post with a 10 ipm feedrate and see if this corrects the issue.
Thanks to all, I will post if the problem still exists
grindaur
Grindaur
Success! Ran through the whole program with no errors, need to keep track of feed rates poor mill his owner causes him all sorts of turmoil.
Great news Grindaur
The Maximum feed rate setting in your machine is meant to ensure that the machine will not run too fast so as to loose steps. No matter what speed you enter into Fusion.
Since yours is a purchased machine the manufacturer would normally set these to the correct value. Are these the original settings the machine came with?
There is one caveat to that though.
If the material you are cutting is hard enough and you are trying to push through it at a speed that is just too fast then you could loose steps or break the cutter.
One of those 2 will give. It's just a matter of which goes first.
There is no point crippling a machine that you would normally cut wood with because you will occasionally cut case hardened Titanium.
Looks like you are on the right track.
@zombieengineer
I unfortunately do not have any information or links on stepper tuning. I personally use the try it an see method and if it fails crank the speed down until it doesn't.
@grindaur - the Sherline recommended MASSO settings for lead screw mills can be found here. The Sherline documentation relating to the MASSO controller can be found here.
@cncnutz - Unfortunately there isn't much information about how to go about calibrating stepper motors (or method that make sense).
The method I use:
  • Test by making several long rapid moves on an axis - the longer the better (use G0 g-code command)
  • Keep the acceleration down and increase speed until it stalls (but make sure the maximum speed is reached during the rapid)
  • Reduce the maximum speed by 20% of the speed that results in a stall
  • Increase acceleration until the motor stalls
  • Reduce acceleration by 20% of the value resulting in a stall
The "increase speed until it stalls" locates the resonance point of the system. Long rapids with low acceleration are most susceptible to resonance stalls. Resonance occurs at a machine specific speed and can take up to a second to manifest, accelerating slowly results in the machine being in the resonance speed zone for a longer period of time (it is possible to accelerate through the danger zone quick enough that the stall does not occur).
The "increase acceleration until it stalls" locates the maximum power point of the stepper motor for the specified speed (generally speed is limited by resonance). Speed x Torque (acceleration) ? Power.
grindaur
Grindaur
Given the limited spindle speed (I do not have a 10,000 rpm setup) and the lower feed rate, I expect to have issues with chatter when I switch to the Aluminum Bronze. I found when doing the lathe operations on this material that I had to play depth of cut to reduce chatter vise stalling the spindle. Oh yeah and while Aluminum Bronze is far better than stainless steel, I could definitely notice wear on my carbide boring bar.
