I have a few questions about ground and drains for shielded cables for my plasma and later router I will attach picture
The din rail with the green/yellow ground blocks attached to it is where I have my drains from the shielded cables landed. Drains are attached on both sides of the din rail. I believe this ok being the clamp on green/yellow blocks have metal clamps and basically turned the whole din rail into ground bar.
Also if the above is ok, being the din rail is screwed to the back plate would that mean that the whole back plate is a ground bar and drains could be landed anywhere on the back plate without creating ground loops?
The blue terminal block is where I have landed my cpc cable from my Hypertherm two of the wires from the cpc are ran over to the relay for torch fire. My plan is to come back out of the encloser with dc power and 50:1 divider voltage to THC. THC up, down, arc ok back into the cabinet to inputs. Does anybody have pictures of how the resistors are connected for inputs. I am having trouble understanding how they are put in and why. Is it because device like proms has to much voltage for input. Again I just really don t understand resistors and how they work.
Don t beat me up too bad on the wiring, I plan to clean it up some before I m done.
