Side connector for stepper control
krobertson
krobertson
In the documentation, it shows the pin out for the 20 pin side connector on the G3, however it only includes two pins per axis, it doesn't have the full 4 pins like for driving normal steppers.
My machine is using the Teknic Clearpaths in an Avid CNC, and I was thinking about doing a simple PCB with the Molex 8 pin connectors for the motors and its feedback sensors. Can the Direction/Step pins on the side connector be used to provide the full D+/D- S+/S- for the motors? This would simplify a lot of wiring but putting it all in the PCB and ribbon cable.
@krobertson
Only a single signal (D+ / S+) is available from the side connector.
The D+/D- & S+/S- are the differential outputs from a RS-422 driver IC (example: 26LS31). The side connector does not provide power (from memory).
@krobertson
Farther to ZombieEngineer's comment, the side connector pins are driven by separate ICs to the differential outputs, they can be used if the drivers have single sided S&D inputs.
@krobertson - That posting was not one of my finest for clarity...
The 20 pin side connector has TTL style outputs (maximum of 5 mA each output). Depending on the application the TTL outputs may be able to drive an opto-coupler, please review the technical specifications of any devices that you intend to connect (Clearpath servo drivers require 8mA input @ 5V - see page 46 of their manual, you will need to use the differential outputs)
The differential outputs (screw terminals) are RS-422 compatible capable of handling 20 mA. The equivalent differential outputs can be derived by using an RS-422 driver chip (26LS31), basically TTL in with Differential out. In theory you could create a PCB that plugs in the side connector that has the necessary driver chips to provide the differential signals.
There was a previous forum posting about issues with the Clearpath servo drivers due to a mismatch with the wiring harness supplied (unable to find the posting but something about the wiring harness was supplied in bag with a diagram and the wiring color code did not match the manual for the servo driver). A couple quick tests with a multimeter could prevent hours of frustration.
