Simple spindle on/off relay wiring
I jog the z axis away from the sensor, then power off. Power on and try home to see if it goes in proper direction. If not check the box in homing direction invert for z axis. The sensor should be low when not seen and high when seen. It looks like that's correct by photo showing it high when the axis is on it. I left my pull off distance at zero I'm not sure if it accepts negative numbers also.
@greg whats your Z axis Min and MAX travel values? please make sure the MIN value is less than the MAX value as having opposite values means that the physical motion is in correct.
greg
Greg
Guy,
The problem is, once it alarms hard limit it locks up any jog ability keyboard or buttons.
I have to shut it down and physically rotate my Zed motor to get it OFF the switch.
I'm going to try swapping out my MOTOR COILS and getting rid of the INVERT and see what happens.
Greg
sorry missed that, ok so does the Z homing input only goes high when you press the homing switch and remain low otherwise?
greg
Greg
Masso Support,
Yes the switch functions low or high activating it with my finger.
It only alarms out during the homing cycle.
The switch works properly if I try to jog past it. It will stop the axis as expected.
Greg
greg
Greg
Jog buttons on Z run opposite of homing direction.
The only way I can get it to home properly, leaves me with the jog buttons reversed
greg
Greg
Checked inverted on the Z Homing page and it runs backwards headed away from the switch.
Get this...I clicked on the Z+ jog button to bring it back up closer to home...had it set to .1 increment (not continuous) and it went rapid Z+ but the switch stopped it before I could hit the escape key!
ecs
ECS
If zero is the top then your maximum travel down is -5.500. You currently have it set at 5.500.
Try changing this on your z axis screen.
greg
Greg
ECS,
Changing the Max travel to -5.5 just reversed all the issues. Tried to step jog in Z+ direction at .100...it tried to rapid into the table.
I set the homing to X, then Y, then Z...X&Y homed and moved off the switch, Then the Z alarmed out instantly after tripping the Z Home switch.
I shut off homing of the X&Y, made no difference.
Any other Ideas!? I'm grabbing at straws here. I already scarfed up a Windoz XP PC so I can run Mach3 again. This Masso control is getting exasperating!
Oh, yes I did double trace all my wiring. This particular machine I built 11 years ago and the only issue I ever had was those darn Wondoz computers dying at the most in-opportune time.
Thanks for the input
Greg
@greg can i please suggest that we do things in small steps first to get basic things working first, otherwise, we will not get anywhere. if the axis are not set properly yet then please only jog in steps and don't use rapids.
do the below:
  1. Set Z axis min travel to -5.5
  2. max travel to 0.00
  3. In homing settings window set home position for Z axis to 0.00
  4. then from F3 try move the Z axis up and down and see if the direction is ok or not, if direction is not ok then goto Z axis settings and invert direction.
  5. then from F3 try move the Z axis up and down and see if the direction is ok or not
  6. after this try to home the axis, now if the Z axis moved down (away) from the switch then pfree escape to stop homing.
  7. goto homing settings and invert Z axis direction, now try to home and the Z axis will move towards the switch (upwords)
try these steps and see how you go
greg
Greg
I followed your instructions and when I tried step 4 ...
I set the jog to STEPS / .100 inches
When I press Z- it moves .100 towards the table.
When I press Z+ it RAPIDS up even though it is set to STEP / .100. I'm not holding the button, just click it once. Does the same using the keyboard!!!!!!!!!!!!!
greg
Greg
OK YEA!!!!
I ran 3 homing cycles with all three axis active.
The JOG functions work correctly also.
Thank you!
Greg
greg
Greg
To all who helped THANK YOU!
Started running my 4K pc order this morning.
After using Mach3 for almost 8 yrs ... I've never heard my steppers run so smooth!
I have my RAPIDS upped to 400ipm. could never get that speed with Mach3 no matter what I adjusted. It took me awhile to figure out which "Maximum Feedrate" was actually maximum rapid rate.
That should be addressed, as it was a little confusing at first.
Now if you could only incorporate K. Dietz' camera edge finding!
Anyway, even after all the frustration, I am very happy with the control.
Greg Rodney
Southridge CNC
