Small portable touch screen.
lilow
Lilow
Could this be used as a remote ?
Why not use a small touch screen with a lead to direct your machine.
A 7" touch screen that seems to accept the Masso touch.
4 wire resistive touch screen.
Is there something I have to add to make it fully touch control ?
Can move the cursor anywhere, just it's behind anywhere it's moved.
Cheers.
@lilow
Ian,
Give us a video showing what you mean by "Can move the cursor anywhere, just it's behind anywhere it's moved"
Is it offset by the same amount?
lilow
Lilow
Breezy.
This little 7" screen shows it should work.
A 4 wire resistive touch.
The situation is that the cursor can be moved but doesn't come close to where it needs to go.
I'm doing some formatting of information to get a remedy.
But I believe this little screen could be used instead of the other hand wheel that gets connected to Masso.
Small enough to hold and hit the needed buttons for a hand held control.
Cheers, you maybe the guy to sort it.
Thanks for the interest.
I'll do a video.
lilow
Lilow
Opps.
Wrong F1 setting.
But it gives a better layout.
lilow
Lilow
Forget about the touch on this module.
Now going to set it up on the G2 early controller with a normal VGA connection.
After 22 years of watching and looking at what's being done.
Once the program is loaded you hardly ever go back to the screen.
Because it is programmed as it should be.
The normal stand up screens are not really needed and take up so much space.
This small one should do everything needed with a very small keyboard.
The touch on the keyboard does everything needed.
I haven't tried moving the gantry with it yet, but the other USB keyboard moves X Y Z to any position.
Cheers.
