SO close ... Masso closed loop nema settings
bobf
BobF
I have a masso touch with Masso closed loop steppers - 2nm on the x/y/b and 3nm on the Z. The Z motor is working as expected. The other 3 not so much - I consistently get alarms on the 2nm motors and I cannot jog any of them (the Z jogs fine). Reading the documentation it explicitly says to not invert the alarms on the masso, so, of course, I had to try inverting the alarm inputs on x/y/b. If I do invert the alarms on masso for the motors on the x/y/b then I am able to job around fine on all axis. Where am I messing up?
bobf
BobF
thanks Breezy. My electrical knowledge is minimal at best. Here's what I've tried so far. Initially I had crimped both the alarm wire and a 10k resistor into a bootlace ferrule, added a heat shrink to the resistor, then soldered a wire to the resistor, again using heat shrink to protect the connection. I did this 5 times for all alarm wires. I then connected each bootlace ferrule to a separate input on Masso. I gathered the five wires coming from each resistor and added all 5 to another bootlace ferrule and attached it to one of the power connectors on Masso. In this scenario the Z worked as expected but the others failed (no alarm lights visible on the motors). I could jog the Z without inverting the Z Alarm but could only jog the others if I inverted the alarms. So ... my next attempt was to solder 5 resistors together onto 1 wire and connect that wire to Masso Power. I used heat shrink again on the wire and each resistor and again used a bootlace ferrule to connect the alarm wire and resistor to a Masso input. Now I'm getting alarms across all 5 but no alarm lights on the motors. So my thoughts are perhaps I didn't solder them good enough the first time where only 1 alarm wire was viable. Should I solder a resistor between two separate wires (x 5), add a bootlace ferrule for the alarm wire and an individual resistor wire, connect each ferrule to an input, then gather the other resistor wires to and to a power slot on Masso. I only have one power slot available on the Masso Touch, the rest are already being used.
Ok, that was a piece of info that I was wondering about, no alarm condition on the motors, so now you need to sort the wiring out.
As MASSO expletive about not inverting the input, means that in the normal state the alarm output of the motor is "grounded" to the motor power supply negative and as the Z axis worked first up, points to you having MASSO PS and Motor PS negatives connected together, as should be.
So you main problem is getting a reliable circuit between MASSO's Motor alarm inputs and the Motor alarm putput.
That most certainly was the case.
Yes, also consider using a network resistor array. This is a device that has one end of a bunch resistors connected to one terminal and the other ends presented as a terminal to connect to the MASSO inputs.
bobf
BobF
I'm about ready to give up. I got these resistors: 1/8 w 10k resistors. As a test I only connected the z motor alarm and placed a resistor between the input and power. Alarm is still showing high on the f1 screen. No alarm led on the motor. Double checked all connections.
It is just a case of determining where the "open circuit" condition is.
As MASSO inputs go HIGH when +24v is applied, by connecting +24v via the 10k resistor the connected device needs to pull the input LOW by "grounding" the device's alarm output.
At the motor end, check that you have +24v on the red wire, then touch it to the negative power terminal on the motor, input should go LOW.
If it doesn't then the problem is that Motor Power Supply negative is NOT connected to MASSO's PS negative, they need to be connected together to complete the electrical circuit.
If it does then you need to confirm that the Motor Alarm output is "internally" connected to Motor PS negative in non alarm state.
bobf
BobF
Ok, let me get this straight in my head. Using 2 meanwell power supplies - 24v for Masso and 36v for the motors. I currently have a wire between the grounds on both power supplies. Does the negative connections go between the N on the power supplies or between the -v connections (since I have 2 motors connected per +v and -v on the 36v would i need 2 wires going to the -v on the Masso ps) and do i even need the wire between the 2 grounds?ps.jpeg
Consider the power supplies as have two parts the AC side and the DC side, you connect the AC side as per your local electricity laws, on the DC side you need to have a common point between all PSs so that the electric current can return its source and this is the -V terminals.
So for the alarm system to work you have +24v current starting from the 24v PS going into MASSO G3, out of the G3 power terminal, through the resistor then to the motor. There through the motor internal alarm circuit and out the negative power wire to the 36V PS negative terminal, now at this point it needs to get back to the 24V PS, that is where you connect a -V terminal of all PSs together.
Most common arrangement for managing power supply connections is to use DIN rail terminal strips, such as this.
images
A connector strip is fitted to the top of each group of terminals to make them a "common" block of terminals.
It is better to use these terminal strips to provide power to your peripheral devices than the power terminals on the G3.
Less chance of damaging the G3 if a wiring mishaps occurs.
bobf
BobF
Arie, You are the best. What's left of my hair can fall out naturally! Connected the -v between the power supplies and got the alarm wires installed with the resistors. Everything is working as expected. Thank you so much!
