minimillaidan
MiniMillAidan
so I know there has been posts before about solid state relays being used to control solenoid valve, I have attached a picture of the diagram I found on the forum that Peter did for wiring a solid state dc relay.
I have also attached a picture of the solenoid valve I want to control with the relay. How do I wire this into the circuit for the solid state relay, the solenoid I have only needs +- dc power to be operated.
I have attached another quick hand sketch of how I interpret the wiring is this correct, if so it means the + power goes through one side of the solenoid coil and out of the other side? Is that correct?
thanks in advance
Aidan
thanks in advance
Aidan
