Solid state relay that works with Masso
pinoy-cnc
Pinoy CNC
Hi Guys,
I been struggling to find a solid state relay that works with the TTL output of masso controller.
I just want to share the one that I done and works without burning my masso.
I have this Chinese, 4 solid state relay that don't works on Masso because the triggering Chanel need negative power and the triggering power that comes on Masso is positive. if I bench test the relay and check if there is power between the negative power and triggering Chanel it's read about 2.5 volt of power not zero.
I read one of post of PETER that it's need zero power between this two.
So I take off one of the solid state relay and hook-up directly to pin 1 of output and one on the ground and it's works.
Here is the video:
