Solid state relay
martin
Martin
Hello, I want to switch my 220v mafell router and the vacuum cleaner with the Masso.
I have built in solid state relays. is this possible and how do I do that?
thank you in advance.
Greetings from Holland.
Martin de Vries
martin
Martin
Hello Arie,
Also de Vries :)
The relay that I have is 230v but the picture that I had attached was taken from the internet and served as an example.
Can I use this relay? i'm a little worried that i'm damaging the controller i'm not electrician.
Thank you for your help.
Greetings Martin
Quote from Martin on July 31, 2019, 11:54 am
Had a look at FOTEK DC to AC Solid State Relay and circuit diagram shows it's opto isolated so it should be safe to use.
Did you have a look at the link I supplied? In particular post #2. MASSO Support supplied instructions for connecting relay.
Further posts discuss how to control the router with M3 & M5 commands.
