spindle analogue output wires when using masso touch breakout board
AJTRADE
New member
hi guy i have just started wiring up a new masso g3 touch with the breakout board and have realised that the analogue wires for the spindle speed control are not extended through the extension cables that are supplied, this is fine as we have not gone to far from the main board.
How are we supposed to connect the analogue wires to the main board as the breakout board adapter dose not allow room for the blue plug to fit under it, do i just have to solder across the pins of the masso mother board i am reluctant to do this but i can see any other way of getting to those wires.
vfd is a fuling bd612 is there any other way to do the speed control
thanks in advance
The analog output for the VFD is pin 1 of the spindle connector (orange terminal block).
The blue terminal block is the analog input (signal from CNC machine to MASSO controller).
There is no software in MASSO controller to use the analogue inputs which is the reason why they are not extended out in the extension board.
Speed signals are connected to the encoder inputs.
