@petermasso-com-au / @masso-support
I've run into an issue with my G3 Masso controller. The spindle output control has failed after a very short time (like only a few minutes) of being connected. It worked perfectly at first but then it suddenly failed to respond. Now when I set Spindle RPM followed by pressing CW or CCW on F2 screen nothing happens. Same nonresponsive result when I enter SXXXX followed by M3/M4 in MDI or a NC program. The CW and CCW buttons on F2 don't activate and the spindle doesn't turn on.
I did all the usual checks making sure the VFD works using an external pot and verified the connections are correct. When I cycle between Hi/Low on the CW and CCW outputs in the F1 screen the Masso relay card is actuating properly. S1000 M3 or M4 MDI Input does nothing. I have Spindle Pin 1 connected to VFD Analog0-10v Input and Masso ground connected to Analog Input Common pins exactly the same way as I had it on my G2 controller.
Unless you have another solution to offer I think it's a hardware failure of the Masso controller. Is there a Masso-approved repair service company here in the USA or do I need to return it to the Masso factory for repair?
Regards, Stephen Brown
G3-6070 running 5-Axis V3.48
