Spindle control outputs
greevous
Greevous
Just curious does the pwm outputs of the masso spindle control system if set to VFD still function. Do they output a pwm equal to the percentage of the 0-10V that would go to the normal VFD or are they not active unless the spindle control is set to PWM. Just curious as I use a VFD on my cnc and I'm looking at adding a laser engraver to it and using pwm from the ccw output would be useful.
Hi Greevous
PWM is not active when VFD is selected. It is either one or the other.
greevous
Greevous
Pity, thought it could be a good way of running a pwm engraver without having to reset all the settings on the masso, I have a G2 so not as easy as it is with the g3. guess back to looking at alternative ideas. Thankyou for the quick answer.
Hi Greevous
One option you could look at is to use a 0-10 volt to PWM board and use that with the CCW output.
I have one on order at the moment to have a play with and see how it goes.
05
greevous
Greevous
That could be a winner (wonder what the pwm frequency of those are, had a look on ebay and none showed a frequency that they operated at), so keen to be able to run the system with a relatively simple way of converting from spindle to laser and back without complicated steps (my Dad uses the cnc for his projects so it can't be too complicated if I've forgotten to return it to spindle operation).
bought this laser (hope it lives up to it's advertising)
https://www.alibaba.com/product-det...pm=a2700.wholesale.deiletai6.7.43e849f3Kflncj
discussed it with them and they have added to their description that it will work with 0-5V ttl so can do a voltage divider, and the amperage for it to function is <1 mA to the TTL/PMW pin since it has its own driver circuit with seperate +12V and ground connections.
stevefrisby
SteveFrisby
I just bought a laser module, and am actually feeling well atm. I am working on a small Arduino project that I think might be the answer just bring all spindle signals through a relay and use a m64 command to switch between laser and spindle so when command is issued the spindle gets relay signals to go off and convert analogue to pwm and what ever signals other signals it might need but maybe with a confirmation (I am using a very cheap oled to display spindle and laser parameters) turning off the m64 will revert back to standard spindle control it would be easy to put command into the gcode and give an automated way of control. I want to use laser for all sorts but for marking boards for attachment to spoil board etc and marking placement of parts would be very helpful. what do you guys think, it is simple to implement and means that the spindle has proper signals even when off
