I'm a newbie on CNC.
I'm assembling a 3DTek Heavy Mill for the Bicton Men's Shed and I want to make it as fool proof as possible.
What we want to happen is when a G code spindle start command is issued it starts the coolant pump and approx 30 seconds after the coolant flow switch closes the VFD is enabled and starts the spindle. I have checked the VFD manual and there isn't a parameter to set for a delayed start, so the delay has to come from the MASSO unit.
Is this possible or I do need to modify Fusion 360's MASSO post to generate G codes to do this. (I was a software programmer in a past life)
