Spindle encoder for lathe
pinoy-cnc
Pinoy CNC
Hi Masso support,
Is this omron E6B2-CWZ1X
Spindle encoder is compatible on masso?
Thanks for soonest reply
Rex
This encoder will not work as it works on 5v and the outputs are differential signals, it will only be able to supply 2.5v to the MASSO inputs and we need a minimum of 5v signal.
Also the PPR is too high, a 100~500 PPR version will work great. Use a PNP encoder that runs on 12 to 24v.
If you want you can also use our new optical encoder that we just released, details here: https://www.masso.com.au/new-homing-sensor-and-encoder-releasing-soon/
pinoy-cnc
Pinoy CNC
Quote from MASSO Support on May 2, 2019, 2:36 am
Thanks, when this will be available
ecs
ECS
The masso encoder is available now. Just email them and ask for it and they will sort it out.
