What are you guys using for spindle motors and speed control for a mill running bT30 tooling looking for rpm 4/5000 for the tools was looking at this NEMA 52
3.8KW AC Servo Drive Motor CNC Kit 15NM Machining 220V 2500R/Min NEMA52
look for induction motor and inverter the problem is 5000 rpm is rare and i don't if there is 5000 rpm, i am using 1.5kw induction motor with 2kw delta inverter and have 2800 rpm
