Spindle sensor
sibyte
SiByte
Hi!
Is possible to use classic inductive sensor for RPM input on milling machine instead of encoder?
Thank you!
sibyte
SiByte
Problem is that I don't have room for encoder, but my machine has already RPM sensor but that is classic inductive sensor and four magnets on the pulley. So four pulses per rotation.
Is possible to add support for that type of RPM detection in MASSO software?
just for RPM I think you can just use one pulse (A input of encoder), do you have a MASSO controller?
cool, I will get this confirmed for you, if its easy then you can also wire the signal to the Encoder-A input and check.
