Stamos S-Plasma 85 CNC with Proma voltage divider
SteelKnight
New member
The plasma cutter I went with was the Stamos 85 cnc IGBT inverter with pilot arc German company.
The cnc port pin 3 is positive and pin 4 ground (-)
Now as you can see by the picture my ground clamp is a + on the bottom left of the picture.
Do I still hook up the Blue proma wire to the 3 pin and black to the 4 pin?
Only reason I ask this is because, when testing the proma with my multimeter my Positive probe is on the positive of proma and the negitve on 1:50 and I am getting a negative voltage. That that would mean I would need to switch the proma wires around or make sure the MASSO DTHC positive goes to 1:50 minus
Also when firing the torch I am only getting about .33v is that normal?
Lastly the plasma on/off the picture below, what do those 2 wire get wired to?
With the case opened I followed my manual trigger to this point. Do I connect the above pic to this through the relay IMG_6874.jpg
SteelKnight
New member
apparently the blue wire on the proma voltage divider is for the negative and the black is for the positive. So, I had to wire the divider to my pins as follows. Pin 3 positive on the plasma is connect to the ground clamps. Pin 4 of plasma to the blue wire. Now i am reading 4.5vs which is great.
The other thing is the torch fire on and off that needs to connect to a relay for the masso board will have to connect to my manual torch fire on pins 1 and 2 of the plasma machine
