Well down to the last of the testing before transplanting into the machine itself. I am trying to get the closed-loop stepper motor to work with the CL86Y driver Documentation Here. From what I read on the install documentation with masso is that the sig + direction + are -4v - +4v where the driver voltage I need requires 5v min am I correct in saying this?
If that is the case and I require 5-24V for the DR+ PU+ linked together from the 24v supply (masso) to and then input the negatives (-) into the masso controller. Below is a diagram. Is this correct? MF + - Not needed. Switches - OFF OFF OFF ON ON OFF ( 1 2 3 4 5 6 ) - 2000 PPR
