Supermax YMC 40
tremeng
tremeng
Thought I would put up some pics so far
tremeng
tremeng
More pictures
headaches have started with wiring
jim-in-michigan
Jim in michigan
Happy New Year
I was just reading you post, I am interested because I am Thinking about retrofitting a Hurco km3p and using the existing servo motors which are still good, and use a Masso as the controller.
@tremeng
ya after reading another post it doesn't look,like you can use the servo drivers and motor combination as they require step and direction signals as opposed to PWM signals that they work with. I'm not sure if there is Anything that can b done about that but I will continue to research this as I need a solution to this also
regards. Guy
@mike_irving
hmm it appears that these drives might accept step and direction signals and reconfigure for PWM signals. Will have to investigate further when I get a minute but if this works it would mean that we could change virtually any cnc machine to a Masso control. To be continued
Regards. Guy
Guy,
Had a quick look at 9g16 drives that Mike pointed to, yes they can be configured to operate on Step & Dir pulse. It requires setup for current & velicity first, then add digital inputs for S&D.
Yah thanks Arie for taking the time to look at that and thanks to Mike for finding it. I will email Glentek later today with specific details about my machine build to confirm that thier product will work, and also enquire about pricing. Should be a good use for the 5 axis G3 that I purchased just for the fun of it
tremeng
tremeng
I m thinking about going to clear parth servos
has anyone had experience with these and what size would you recommend for my machine
