G01 Y1.2459 F100.0 is causing my Gcode to hang up. I don't see any error or warnings. From the MDI also G01 will not work while G00, M03, M05, S1000 etc all work just fine.
Thanks,
Chris
Update: OK, not that anyone else might do this but it turns out that if you check the Limit Maximum Feedrate check box in general setting and neglect to enter a value other than the default of 0.000 your G01 will not work and your programs will never time out Silly mistake.
