locomobile
locomobile
Hi
Having recently purchased two Masso units I am starting to connect the first to my Syil x4+Milling machine. This machine has run for a number of years via a parallel port setup on an Ethernet Smoothstepper. I have decided to move to Masso to eliminate Windows
I have a high spinal injury and am anxious not to have to do a complete teardown of the machine to use Masso. The machine has a type of breakout board that manages connections. I also make good use of the manual control the machine offers using its own MPG when not in CNC mode.In short, I would like to use the parallel cable to connect to Masso.
The connections are easily made using a simple parallel breakout connector. Cable pinout is below. When using Mach3 both signal pins need to be as shown below and set to active low
Pin table attached
Signal 1 (pin 1) is mapped to Output 1
Signal 2 (pin 9) is mapped to charge pump
My question, is this possible and if thought to be, how to manage the two signal outputs
Many thanks in advance
David
Pin table attached
David
