@ross
Thanks for the invite to talk via LINE. I'm not comfortable using these modern communication aids - too hard to teach an old dog new tricks I suspect!
Not to pleased about this at the moment, I just think we need some rock solid wiring instructions to follow when doing these things.
I'm fairly sure the damaged integrated circuit is a memory device and if this is so it will have no connection with the outside world. It's difficult to understand how this can happen. I guess you will have to wait till
@masso-support gets back to you.
It is practically impossible to have
rock solid wiring instructions simply because of the enormous variety of peripheral boards and/or equipment that need to be connected to the Masso to do a specific job. And as if that isn't difficult enough each manufacturer of these peripheral devices have their own standard electrical and physical protocols.
I do think however that Masso have gone a long way with their range of inputs and outputs toward making a unit that can be connected to to a great range of external devices. Congratulations to them for this and also for their support, they are on this forum almost daily solving problems. One doesn't get that attention from many other equipment suppliers.
Like COM on the MPG wiring diagram, is it negative or positive. THC wiring is the same.
Nomenclature is always a problem. Unfortunately it more often than not needs somebody who understands the language and has the skills to nut a problem out. The situation is that in many cases (maybe most) is that the guy (or gal) trying to put systems together doesn't have skills in this area. This is where support comes in and to a much lesser a degree others like yours truly.
One can understand it from the point of view of a manufacturer of peripheral equipment. They are trying to build a piece of equipment that is compatible with a range of other's equipment, they are not designing for Masso or any other specific device.
I am aware that the foregoing is not much help to you at the present and I can understand your despondency but hang in there and there and it will all work out. Patrick
