T# M6 command doesn't do the auto change
garyit
garyit
Hi, we have a new Cancam machine with auto tool change system. At the first week, when we input T# M6 command and ran it, the machine did auto tool change automatically. But now when we input T# M6 command, the machine pops up a window reminding we change the bit manually, then press cycle start. I wonder if we changed some setting accidently so that the machine can't do the auto tool change. Thanks!
Regards
Gary
garyit
garyit
Hi Arie,
Here is the file. Thanks
Regards
Gary
  • MASSO-Settings-G3-8998-Mill.zip
@garyit
Gary,
From your config file
==========Tool Changer==========
- Tool changer in use: 1: Manual Tool Change
- Tool clean air blast time (ms): 0
=============X-Axis=============
So yes you managed to change to manual tool change.
From Inputs & Outputs
Input 10: Tool Changer - Input 1, Invert: No
Input 11: Tool Changer - Input 2, Invert: No
Input 12: Tool Changer - Input 3, Invert: No
Output 1: Tool Changer - Output 1, Invert: Yes
Output 5: Chuck Clamp M10/M11, Invert: No
This indicates your machine was setup with Linear Tool Changer Type 2. https://docs.masso.com.au/wiring-an...mill-tool-changers/linear-tool-changer-type-2
