Testing a Touchscreen
angelars
AngelArs
Recently bought a new touchscreen and I am trying to test whether it works with the Masso or not.
I was under the impression that when you first turn the Masso on, that it allows the touchscreen 20 presses, so that you can see if your screen is compatible with the Masso.
However, my new touchscreen isn't allowing for 20 presses. The touchscreen function stops working after 11 presses.
Should I "assume" that the touchscreen is compatible, or could something else be wrong?
Also, where is the link to purchase the touchscreen add-on? Thank You.
optik
optik
angelars
AngelArs
Thank you Optik for that clarification!
I will purchase the upgrade and also add the iChawk ZB190TC-591R 19" Touch Screen to the list of supported touchscreens.
I will post a full review of this touchscreen next week, once I've tested it.
Once again, thank you very much for all of your help with this.
