Testing G-Code issue
adstaggs
adstaggs
I am running some gcode for testing my plasma cutter but it stops then gets a Alarm Touch Error, do I need to have the plasma cutter powered on and air connected to get this to test?
Can you please provide some more details of your setup, such as what THC you are using and what THC settings have you done on MASSO. Please provide all the details of your setup and requirement.
So have you wired the torch touch switch to one of the MASSO inputs and assigned it to "Torch Touch Signal Input" ?
so your Z axis comes down, touches the work piece, stops and set that as Z0.00?
Do you have a photo of the alarm?
  1. Firstly please load v3.31 that was emailed a few weeks back, if you haven't received the copy then let us know your serial number and we will resend. its good to run the latest version of the software.
  2. Can you check and see if the torch touch input shows L or H when its not triggered.
adstaggs
adstaggs
this is what I am running now, did not get the update.
MASSO Plasma 5-Axis Update v3.29.1a (Tester Release) for Serial No. 5A-2119
  1. Just resent the software now, can you please check your SPAM and JUNK folders.
  2. Also were you able to check the above mentioned signal?
Can you check homing input has been set for Y axis and it only shows H status when the homing switch/sensor is triggered.
adstaggs
adstaggs
I notice when I install the v3.31 I get a white screen but no percent screen, I wait for the green led to stop blinking then reboot and login but still no action on Y axis.
