The ESTOP seems has no function ,
micronami01
micronami01
The ESTOP seems has no function ,since even connect (PWR+ ) to ESTOP directly, means short (always high) . It remains error(ESTOP). This is Brand NEW G3 , did you test OK before sent it
out?
I use space(keyboard) to YES HIGH. Then it is no error ,but it is no function.
Hi micronami01
All Masso units are tested before being sent out so it is a bit strange that it isn't working.
Connecting a wire from Estop pin 2 to the +ve of the power supply should show the Estop input go high and removing it should make it go low. The input should not be inverted.
Is the Estop indication on the screen flashing Yellow or Red? It is normal for the Estop to require resetting when you start Masso so simply simply connecting a wire between +ve and Estop will not remove the Estop on startup. You ultimately must install a switch so you can reset it.
Could you just review this video and see if it helps with the issue. Let us know your findings and if you are still having a problem we can investigate further.
