Threading Wizard Causes Masso to Crash
gear
Gear
I am trying to run the threading wizard and when I try and run the code Masso crashes. Has anyone else had this problem or suggestions on what I am doing wrong?
ecs
ECS
@gear - go to the F1 screen and check the indexing is correct. Turn the spindle over slowly and check with each pulse it counts on the screen. Make sure they add up to the encoder disk. As westy and myself have found out a tiny finger print mark can cause an additional count and throw everything out.
