Hi Peter,
I've included the requested settings text file below.
To clarify, the problem I'm having is sometimes immediately after setting a zero and other times after using a tool the height seems to change and this causes the the tool to either cut in mid air or to crash. This can visually be seen in the video where the tool offset seems to show one value (the value it should) then when clicking...it shows the true value that is driving the height offset of the tool currently. In the case of the video the tool started cutting in air mid job. I've started watching closely the values the tool setter outputs and confirming those with a surface plate and height gauge. So far all the it seems when the heights change on me they always change by a large amount (20-50mm).
I'm hoping yourself or others from masso can confirm there is no scenario where the tool offset should ever change or show different value on the main offset page vs if you click on an individual tool without the user typing in a new value or commanding a tool height to be set via a tool setter. It would seem to me, even outside of the context of whats going on in the video that should likely not ever be something that happens.
After breaking a number of more expensive end mills to this problem in the machine and destroying one tool holder I'd like to get this sorted asap.
Edit: seems I cannot upload the text file so i've copied and pasted it below:
MASSO Serial No: G3-7186
Mill 3-Axis v3.48
Settings file format: v2.20
==========General Settings==========
- Machine units: Inch
- Machine bed orientation: Standard
- Load 'autoload.nc' on power up:
- Disable Soft Limits:
- Disable Hard Limits:
- Enable cycle start on door close:
- Limit maximum feedrate:
==========Homing Settings==========
- Seq 1: X: 0 Y: 0 Z: 1 A: 0 B: 0
- Seq 2: X: 0 Y: 1 Z: 0 A: 0 B: 0
- Seq 3: X: 1 Y: 0 Z: 0 A: 0 B: 0
- X-Axis Direction Invert: Ticked
- Y-Axis Direction Invert:
- Z-Axis Direction Invert:
- Homing Feedrate: 30
- X-Axis Sensor Pull-Off: 0.010000
- Y-Axis Sensor Pull-Off: 0.010000
- Z-Axis Sensor Pull-Off: 0.010000
- X-Axis Position After Homing: 0.000000
- Y-Axis Position After Homing: 6.400003
- Z-Axis Position After Homing: 11.500007
- Request Home on startup:
- Request Home after E-Stop press:
==========Spindle Settings==========
- Encoder (Pulses per revolution): 100
- Spindle Control Method: VFD (0~10v)
- Spindle RPM at 10 volts: 5333
- Spin UP delay (milliseconds): 4000
- Spin DOWN delay (milliseconds): 2000
==========Lubrication Settings==========
- Lubricate after: 0(hr) & 10(min)
- Lubricate for: 0(min) & 3(sec)
==========Tool Changer==========
- Tool changer in use: 1: Manual Tool Change
- Tool clean air blast time (ms): 0
=============X-Axis=============
- Motor: Distance per revolution: 0.200000
- Drive: Pulses per revolution: 1600.000000
- Maximum Feedrate: 80.001739
- Acceleration: 50.000488
- Travel Minimum: 0.000000
- Travel Maximum: 14.500008
- Backlash: 0.000000
- Direction Invert:
=============Y-Axis=============
- Maximum Feedrate: 80.000045
- Acceleration: 60.000362
- Travel Maximum: 6.400003
- Direction Invert:
=============Z-Axis=============
- Maximum Feedrate: 70.000076
- Acceleration: 35.000038
- Travel Maximum: 11.500007
- Direction Invert:
==========Auto Tool Zero Settings==========
- Only auto tool zero when manually requested: Ticked
- Tool setter X position: 0.000000
- Tool setter X enable: Ticked
- Tool setter Y position: 5.294003
- Tool setter Y enable: Ticked
- Z safe distance to tool setter: 7.000004
- Tool zero feedrate: 10.275597
- Tool number to skip: 99
==========INPUTS==========
EStop: EStop, Invert: No
Encoder: Signal - A, Invert: No
Encoder: Signal - B, Invert: No
Encoder: Index, Invert: No
MPG: Dial Signal - A, Invert: No
MPG: Dial Signal - B, Invert: No
MPG: Select X, Invert: No
MPG: Select Y, Invert: No
MPG: Select Z, Invert: No
MPG: Select A, Invert: No
MPG: Select B, Invert: No
MPG: Resolution 1, Invert: No
MPG: Resolution 2, Invert: No
MPG: Resolution 3, Invert: No
Analog: Input 1, Invert:
Analog: Input 2, Invert:
Input 1: Z - Home Sensor Input, Invert: Yes
Input 2: X - Home Sensor Input, Invert: Yes
Input 3: Y - Home Sensor Input, Invert: Yes
Input 4: Probe Input Signal, Invert: Yes
Input 12: Tool Setter Input, Invert: Yes
Input 19: Cycle Start Button Input, Invert: No
Input 20: Cycle Stop Button Input, Invert: No
==========OUTPUTS==========
Spindle: CW, Invert: No
Spindle: CCW, Invert: No
Output 1: Coolant Flood, Invert: No
Output 3: Auxiliary Output 1, Invert: No
Output 4: Auxiliary Output 2, Invert: No
Output 5: Auxiliary Output 3, Invert: No
