Hi All, i am using Fusion 360 to generate my tool paths and lately i run into situations where i have to cut a part from both sides. Fusion CAM supports a setting called 'tool orientation' where you can override the Z axis setting from the setup. This is useful because i can then use rest machining. Unfortunately the MASSO post does not support this. I get around this by creating a new setup in Fusion CAM with the desired upside down Z-axis. But with this i cannot use rest machining and the tool path will cut a lot of air eating a lot of time. Did anyone else run into this and maybe find a solution? Is there anything i can do myself? I am a software guy and might be able to make a change to the PP with some help.
thanks,
Joachim
thanks,
Joachim
