Hi everyone,
I'm setting up a MASSO for the first time.
We have a G3 Touch (configured as a Mill).
To connect a probe setter (that will also be used as a probing) I used one of the red-colored Power connector and wired it to two inputs going thru a normally closed switch.
Both inputs were displaying as "High" on the F1 display but are now showing "Low" on Invert.
Pressing on the setter triggers the switch and the signals go High on both inputs.
It seems to work fine this way but I would like to make sure... do I need to add a resistor somewhere?
Thank you
David
Thank you
David
