Toolchange problems
martin
Martin
Hello everyone,
I have a problem with the auto toolchange (manual).
After homing, the spindle goes to the tool change position and does the probing.
I then load the g code, set the x-y position and probe the Z axis.
When I then press rewind and then the start cycle, the spindle sometimes starts turning immediately and starts milling.
But it also happens that with the same gcode it goes as it should.
Someone the solution?
Greetings Martin
Hi Martin,
I'm not quite sure what you are describing as the problem.
I'm assuming you are saying that sometimes it doesn't request a tool change and sometimes it does.
Masso remembers the last tool number even after it has been powered down. If the tool number matches the tool change requested it will ignore and move straight to machining.
If the tool number is different it will move to the tool change location and request a tool change.
