Can somebody tell me what triggers a touch error? Does it monitor my ohmic sense with a time closed trigger?
Not sure if this was covered earlier but my table is acting up and I don t know where to go.
The table has been working great but when I let it sit it seems to happen every now and again. And as strangely as the problem started, it stops and works fine again
I load a cut file, zero out and cycle start. the torch makes a cut or 2 moves to the next location, begins to lower the Z and the controller errors out in a Touch error inches above the work piece. Re-home and restart and the same thing happens. None of my settings have changed since the last successful use. I've watched the "trigger" light on my ohmic sensor relay and it is not calling for closure when the fault happens. Same G code file that worked 3 weeks ago faulted out today. This has happened with 4 different versions of software. I did also do the 3.44 update and it still happened. The setup is DIY 4x8 plasma table, ohmic sensing, no thc as i havent been able to get the proma to work well so i gave up, Slaved X axis, s/n is 5A2217
