touch plate clarification
gok
GOK
Hello sir.
from looking at Masso's touch plate instructions for wiring diagram, I was a little confused.
as a result I created a diagram of how i am connecting the wires. one with and one with out the spindle connected to the -v 24 pin.
could you tell me if I am correct or totally confused. I labeled the connections A, B, C, D, and E in hopes that you could tell me if one of the connections is needed.
Any help would be great sir :)
George
clover
clover
@gok
Yes, there needs to be a connection between D and E to complete the electrical circuit when the cutter touches. Remove the A - E connection.
The 3.6K? resistor is OK, Masso recommend 5.6K?.
adstaggs
adstaggs
This is the correct setup for the touch plate with the masso?
3,6 ohm resistor connected to + and B then D - to spindle with a clip?
