Touch Probe Wiring
routertrav
routertrav
Please forgive this question, as I am no electrical engineer. I am about to start wiring the touch probes. The documentation says to use a 5.6k Ohm resistor. I have a 5.62k Ohm. Will this be ok to use? I just do not want to burn something up before I get a chance to use it ?
yes you can use any value around this number and it won't damage anything on the controller, the worst is that either the MASSO will not see this signal or this resistor will heat up but you can't damage the controller till the point that the voltage to the input is not more than 24v
