Can you use a multi-meter and measure the voltage at the MASSO controller between the input pin and GND?
For logic low should be < 1.0V
For logic high should be > 3.5V (based on TTL logic standards)
The actual trigger point for logic high is highly dependent on the components. The opto-isolator chip has a wide variation in sensitivity, not uncommon to see a factor of 12 between the lowest and highest current gains on a datasheet. It is quite possible that the trigger voltage for logic high can vary between 1.2V to 3.4V (0.2V to 2.4V above the logic low threshold, it could be lower than that based on the actual circuit on the other side of the opto-isolator).
The LED in the opto-isolator chip has a "forward voltage" range of 1.0V to 1.3V (hence the logic low threshold above). I believe MASSO has added a 6800? resister in series with the opto-coupler from my investigations.
If you are using a resistor in the input circuit: The ideal resistor to get 5V at the input terminal is given by R = 1700 x (V - 5), for V=24 then R=32.3K?, for V=12 then R=11.9K?.
Using a lower value resistor is acceptable, just means the input terminal voltage will be a bit higher.
I have just checked the triggering voltages the inputs on my MASSO G3 controller and the following are the results:
