Trouble with tool setter
Hektoen|
New member
Hello
I have wired up a two stage tool setter, and accoring to manual it is workin.
Bot signals are low on input screen and goes high when trigered.
But here is my problem, My machine will not go down and touch the tool setter
I have watched the youtube video several times and put inn settings.
Machine goes to the tool setter, Drives down in good speed, But then turns and goes up slowly without touching the plate.
What are im doing wrong?
  • G3-14377 - MASSO 5-Axis v5.07, WiFi, Touch, QR, Multi-Head.HTG
Please supply PRINTABLE config file, the attached HTG file is your controller's software/firmware which can only be installed on your machine.
Printable settings File​
The printable settings file option is available on the MASSO G3 and MASSO Touch only. It cannot be loaded back into your MASSO but it is your settings in a readable text file that you can uses as a written backup or share with others to help diagnose any issue you might have. It is one of the most valuable pieces of information that you can send to MASSO Support or share with others if you have an issue.
To save your printable file press the
button and the printable settings file will be saved as a txt file to your Flash Drive under the MASSO/Machine Settings folder.
