tayloredtech
TayloredTech
When I power on the Masso all relays turn on from the TTL board even though outputs are on low (loud click from each relay and relays get warm and I tested the NO/NC) you'll see in the video that when I go from low to high I do get led feedback on the relay but no change in the relay state..
I have two seperate units and they both do the same thing from both banks of output terminals.
Is there something I'm missing here?
Each relay board has a 10 pin header that is VCC (12v) then in 1-8 and a ground to finish. All wiring is correct so I'm a bit lost..
I'll find the eBay link shortly
**EDIT**
eBay seller had it listed as VCC 12v but it needed 5v as the relays were 5V.
**EDIT**
