Umbrella ATC Issue
minimillaidan
MiniMillAidan
so I ve been trying to configure my atc recently had quite a lot of success however the issue I have is...
when I do a tool change the pdb unclamps before the carousel is in position under the spindle nose, this means that the tool falls out of the spindle before carousel moves over.
so normally an atc is mounted on the left hand side of the machine but on my machine it is on the right, with the atc logic does it, say the atc is moving from the left to right to be in position? As I need it to say it is moving from the right to left to be in position..
Any help would be much appreciated
Thanks Aidan
Issue resolved
After updating to Version 4.0 software the tool changer works correctly.
