Update 3.37 home button
doc1
Doc
the home button on the jog screen does nothing when pressed with the mouse .
still have to hit the crtl +alt + home to get it to work
when you press the home button, it will change and display to hold it down for 3 seconds, you can only home from this button if you hold down for 3 or more seconds as a safety thing so that its not clicked by mistake.
peter35
Peter35
I have servo motors on my XY&Z axis and a stepper motor on my 4th axis. 3.37 update, when homing machine x axis also activates a axis, a axis is set to angular and not slaved at all. a axis rotates in one direction only when homing.
I reverted back to 3.36 and all is working as it should.
3.37 has fixed tool clamp issue.
I will leave machine with 3.36 for the moment as l need to be running all 4 axis for a job.
peter35
Peter35
Have attached settings files. 3.36 was copied today and l believe 3.37 was done after upgrade yesterday.
3.36 worked all day yesterday without issue on 4 x axis.
If 3.37 is not copied correctly l can reload this afternoon once job is complete.
  • 3.36-MASSO_Settings.htg
  • 3.37-MASSO_Settings.htg
Quote from MASSO - Support on August 22, 2018, 9:22 pm
So that's the trick with the new home button. You might want to add that gem to the release note! Thanks for all the hard work developing this software. Its looking better and better every week.
