v3.38 not updating
angelars
AngelArs
Followed direction but each time when I boot up the Masso it doesn't update (no yellow bar).
What should I be checking?
Made sure USB stick was formatted correctly and file names were not changed.
tayloredtech
TayloredTech
Quote from AngelArs on October 27, 2018, 4:07 am
Have you read the how to update page/ video? ...
angelars
AngelArs
Yes, plugged directly into the Masso as per the instruction page. Formatted for fat32. File names have not changed.
I've updated before and it worked great, that's why I'm wondering why this update isn't working.
As soon as I turn the Masso on it goes directly to the password menu page, no yellow update bar...
Have you tried a different USB drive?
Also some users have reported that on some drives changing the allocation unit size can have a difference, can you please try different settings.
bictonmensshed
BictonMensShed
Just updated the Heavy Mill.
First attempt got progress bar 100%, restarted MASSO with USB stick left in it repeated upload and requested restart.
Second attempt, removed USB before restart and MASSO started OK with v3.38 loaded.
Third try, with update files still on USB stick, MASSO reloaded update and requested restart, etc.
Forth try, with update files removed from USB stick, MASSO started OK.
angelars
AngelArs
Quote from MASSO - Support on October 29, 2018, 4:29 am
Yes, bought new drive.
Formatted for Fat32.
Installed both files.
Inserted in Masso (with Masso off).
Turned power on.
Masso went straight to main screen asking for password.
Tried both USB ports, same outcome.
At this point I'm thinking it must be something with the files sent.
Could they be resent?
Quote from BictonMensShed on October 29, 2018, 7:06 am
it looks like MASSO is unable to rename the file after finishing the update, MASSO renames the after the update so that it does not reload the software again on power up. So in this case please just delete the files from the USB after loading the update.
angelars
AngelArs
Quote from MASSO - Support on October 30, 2018, 8:35 pm
we can send the files but most likely the files won't be the issue.
Sorry, don't use facebook. Could you please just resend the files?
If it doesn't fix the issue we'll just have to try to figure something else out. Thanks.
just emailed the files again and if you want we can do this over the phone as its been going on for few days and we can get this sorted on priority.
