V3.46 Plasma Update
segoman-designs
SegoMan DeSigns
@masso-support
RE:
G3-5765 - Plasma 3-Axis v3.46 , Wi-Fi.HTG
Did you get your files mixed up? I just ran the update and I no longer have options for THC and the Homing shows only a spindle setting.. There are probably other errors as well I just did not look for them. I re-installed v3.45 and tried reloading the settings only to find out you rewrite the existing .htg file with current settings and not time stamp them into multiple files. (I saved the setting from 3.45 1st then the 3.46 second) so Now I have to manually reprogram the entire set-up from scratch.. Why don't you allow multiple htg files and allow us to rename them? You auto number screen shots.
we are looking into this issue, the Plasma versions sent by the server seems to have some issue, we will be emailing the software for Plasma user again today.
v3.46 has new settings data format and that is why loading old settings is not possible, sorry but its a design limitation.
@segoman-designs please find the attached v3.46.1 that I pulled manually from the server to check, please let us know if this resolves the issue.
  • G3-5765-Plasma-3-Axis-v3.46.1-Wi-Fi.HTG
segoman-designs
SegoMan DeSigns
That one works..
Here's an edit for your online documentation:
When saving calibration settings the previous setting is overwritten, it is advised you save this (MASSOSettings.htg) file in your working computer in multiple date/time stamped folders. Or you will loose 1/2 days work reprogramming your machine...
