V3.47.4 Tool Changer Options
@masso-support
I just loaded V3.47.4 on my G2 (5A-2806) and noticed that both the Linear and Umbrella Tool Changer options are listed as "not available" in F1 screen. I only have the Manual or High-Speed Rotary Tool Changer available. Is this a temporary issue with this version or a bug?
Also, I could not find the High-Speed Rotary Tool Changer in the documentation. I am in the process of wiring up my system using the required sensors and logic for an Umbrella tool changer. Does the High-Speed Rotary Tool Changer version use the same logic as an Umbrella version?
Thanks for your help.
due to the limited memory on the G2 and new features added, some tool changers will need to be requested as we have to manually enable that tool changer and disable other tool changers for each controller serial number. you can email on support to request the software.
@masso-support
Thank you for clarifying this for me. Old guys like me tend to run out of memory as well sometimes :) Thanks for the continued support of the G2 users. I really appreciate everything that you are doing for us.
