mtlchsr
Mtlchsr
Hi all, Mtlchsr here from down under in NZ....I am trying to eliminate endless issues by converting my Vertigo MX2 (A kiwi product) router to Masso. The MX2 is brand new, and comes with a 'smoothie ware' controller board /box and USB connection to the PC. CNCj was the interface for the routing files. I have Vectric Aspire for making my designs/code. Had nothing but trouble and random issues (read spoilt work, hang ups, failure to home properly, agro, etc) from the get go. Final straw came when the whole file that was running 'disappeared' off the screen and the router decided to dig through my spoil board and gouge ugly hole into machine bed... all in two shakes of a snakes leg, .....ahhhhhh . Support from Vertigo has been , lets say, pathetic to say the very least. I did a rant on their face book page once and that got a response, ... alas the promises and fixes were as useless as each other.
Anyway after an inquiry to Masso I took the plunge.....
Also I should note here I don't know much about electronics at all. I do know that a 4000 volt 'whack' from the electric fence certainly gets ones attention + a mental reminder note to try and not let that happen again. But I can follow coloured wire diagrams even if I have not much comprehension - dangerous I know.. but this is NZ - DIY capital/center of the Universe. !
So, $$$$ later I have the hardware necessary... 1 x Masso G3 with the MGP Pendant + 24V power supply, 1 x Gecko G540 drive system + 1x 48V power supply.
I have watched and read the support documentation and done all that I can do without help/bothering folks when the info is available already.. so here is where I am up to....
I have the Masso unit up and running with screen, keyboard, mouse and software loaded. (Wow!) Everything looks ok thus far. I have the Masso mounted to a box on a din rail with the Gecko unit in there as well. I have a decent heat sink on the back of the Gecko with its own fan as well.. cool it should run. Next phase of the project was to wire the Masso to the Gecko, I have followed the wiring diagram available under 'Support' drop down... then 'Documentation' option... then following the links all the way to https://www.masso.com.au/masso-documentation/?section=gecko-g540 page. All was going well untill (yes I know that is spelt wrong, but I learnt it wrong way back in primary school last century and now the die is cast and without copious amounts of Gu'mnt funding as well as free endless tax payer paid councelling (same issue ) I don't think there is any reason why I could possibly change a bad habit. AND who made up the spelling rules anyway. !) .... continuing.... All was going well until (!) the last wee bit of the diagram where it has the A axis with the green wire to pin 25 on the Gecko D-type connector. 1) the Masso G3 A axis connection block has 4 pins - same as the X, Y, Z green blocks - not 3. Also pin 2 is S- not D+ ? That is pin 3 is it not? Then there is no 'G' pin either. Am I to understand that actually the blue wire to the Gecko D-type connector pin #9 should be at pin 3 (D+) on the Masso unit and the green earth wire should be into any one of the black 'GND' pins on the Masso board ? Or am I to understand that the green wire can be shoved into pin 4 (D-) as that is the same thing as 'Ground' ?.... I am confuzzled. Can someone in cyber electronics land defuse the confusion for me. (please) Then I can get onto the major issue looming in the whole conversion process...... finding out what wire pairs go to what stepper motors on the MX2.
I should also say that I am presuming I need the A axis wired up as the MX2 has 2 steppers for the Y axis - 1 on each side of the router bed - these will need to be in 'sync' (trendy wording I know) 'slaving' the second stepper motor is the technical wording I think. Thus Y and A will need to be together somehow. And even if I was not using A at all , that green wire would need to have a home would it not?
Thanks in advance... but be warned ... there will be more questions for sure and if you don't reply I am going to have to apply for more counselling etc... oh and where are the emoticons in this thing..
