I am not sure of the connections of the VFD to the Masso our VFD is a Delta VD 022E21A I have attached the pin layout on the VFD. I need to know which inputs to connect to.
please see if the below links from MASSO documentation can help as most of the VFD wiring is similar, the only things different will the parameter settings on the VFD:
