Having trouble with my VFD to Masso connections .. I can't get the Masso to run the spindle motor in both forward & reverse from an M3 /M4 command.
I know the VFD is operational because Forward & Reverse & Speed Control all work fine from the VFD control panel ..
It's when I try to connect to the Masso that I run into problems .. I can get either M3 OR M4 to work depending on which wires I connect to spindle terminals #6 & #7 .. but I cannot get either M3 or M4 to work when connected to spindle terminals #4 & #5
My VFD is a brand new Hitachi WJ200 .. I have studied & re-studied the Masso wiring diagram for Hitachi drives .. I have studied the Hitachi manual to make sure all settings on the VFD are correct .. and as previously stated, it seems to me the spindle terminals #4 & #5 are not functioning.
Please advise, Thank You
