I submitted these questions to Masso support but welcome
any advice those more experienced than myself might also offer.
I have a very nice lightly used Webb 5VK knee mill with a Prototrak M2 3 Axis CNC retrofit. This uses their integrated servo/drivers
for X and Y the Z axis is not powered. It also functions as a DRO and has glass Accu Rite scales on X Y Z.
I plan on purchasing an Elrod Z Axis quill drive from servoproductsco with their smart Z axis option
that uses a Fagor scale for Z. I supply the motor and amplifier for that.
I am very interested in converting this to use a Masso G3 controller but have questions.
1) Could the G3 use the scales and function as a DRO in all 3 axis when used manually?
If not without modification what would be required?
2) Is the controller compatible with the existing X and Y
integrated servo drives and motors from prototrak?
3) Is the controller able to also use the scales for positioning/confirmation from the scales
or is it better to rely on the encoders and use a backlash comp?
4) If I wanted to use both the scales and encoders and have the control use the scales for
(what I assume would be more accurate) positioning is this possible or even desirable?
Any input appreciated.
