DavidR8
Active member
I have a Weiss VM32 mill that I'm planning to convert.
I lucked into a private sale of an new Arizona CNC kit for my model of mill, new DMM servos and drivers, Masso G3 and pendant plus a bunch of other brand new kit.
Part of my planned conversion is a swap of the BLDC spindle motor to enable control of the motor via the controller interface.
The servos that I bought in the kit are DMM so I looked at a DMM 1.8 HP AC servo and driver. North of $1000 USD/$1400CDN is too expensive for my blood.
I can get a no-name AC servo and driver off eBay for about $750 CDN which is a bit more palatable but still expensive. And the sketchy documentation, tuning software is not great.
I considered an AC motor and VFD but the motors in the 1.5 HP range are heavy beasts and I'm not keen on putting that much weight on the head of my bench mill.
Ran across a lathe CNC conversion that used a 90V DC treadmill motor with a KBB driver that uses a potentiometer to control speed. The conversion I saw used a board to take a PWM signal from the CNC controller to provide input to the KBB driver board (instead of the potentiometer) allowing full control of rpm and direction of the DC motor.
KBB DC motor driver board:
www.emotorsdirect.ca
PWM board:
cnc4pc.com
In the documentation for the latter is this pdf showing the PWM board connected to an HTG control board
Does anyone see any flaws, pitfalls or caveats with this approach?
eMotors Direct - Canada's Online Source for Electric Motors, Gearing, and Controls
PWM board:
Welcome to CNC4PC
CNC4PC: Reliable CNC Motion Control, Breakout Boards & Interfaces for Automation Systems
